strideredc
Next up is my 6d mag 35w full regulated hotwire runtime monster
This was built specifically as a usable hotwire not a ''set paper on fire, 5 min runtime''!
The throw with the smooth reflector is amazing as is the runtime, it's as white as a hotwire gets.
I have never measured the runtime but I was told it should be around 2 hours? My memory isn't that good these days so if anyone knows better let me know and I will put it in the add. I have had it running for over 1.15min.
The beauty with the AWR hotdriver is it can be adjusted via two pots so you can set the Vout to whatever you want. It will also cut the power when the batteries run out so you won't over discharge them. It really is quite an amazing bit of kit. It is the high power temp regulated version and its softstart.
KIU bi pin scocket
sop aluminum reflector
AWR fully regulated and adjustable voltage driver
Borofloat glass
And all resistance mods
Osram 64275 6v hotwire bulb running at 7.10v and 3 spare bulbs
I think its about 1500 bulb lumens? (whiter than an A2)
Usual story too many lights and some must go…
I have 6 d cells 10,000mah but wont include them as the weight would make this very expensive to ship. If you are in the uk or really want them we can work something out…
$120 plus post post is £8.67 thats about $10 at the moment. if you want it tracked its £18.34
KIU bi pin scocket
Borofloat glass
