6p drop in with long runtime?
Reptilezs
MA, USA
got a stock surefire 6p. looking for a led drop in with long runtime. i know that the surefire p60l is about 4 hours. anything longer out there?
Malkoff M60LL is hard to beat for runtime. Or you might look at some of the drop-ins with multi levels such as Dereelight.
Any of the multi-mode modules.
The M60LL is 85 Lumens... identical output to the P60L but ~2x the run time.
You could try a 0-100% Q5 from DX, if you don't care when you get it.
I've been 'waiting for supplier' for about a month.
The Solarforce 1 Mode R2 dropin has a reduced output of 150 lumens and can go for at least 3 1/2 hours on an 18650
The OP should note that an 18650 cell physically does not fit in a stock 6P body, without modding. If you want to use a single 3.6V cell in a Stock 6P, go with the 17670 cell.
The OP should note that an 18650 cell does not fit in a stock 6P. If you want to use a 3.6V drop in 17670 is your best option.
I was being generous with the 18650 number. A 17670 can go for about that much while an 18650 can go for 4 hours
I have a M60LLF = 8 hours plus.
I have it in a G2 with a Solarforce 18650 extention and use it with 2 17670 cells. I also use it in a 6P w/18650 extention and put 2 18650 extentions for really long runtimes. (my 6P bodies are bored).
