Noted; avoid Dorcy & Saturnus.
I don't recall if there was ever a Saturnus-branded lamp in this size, I was just using that as a comparative to the "Germany or Romania?" question (or non-question).
So, 72207 (Germany) vs 003427291 (Romania), sounds about correct as far as part #s go?
Not really. 72207 is left over from a long-ago Hella USA parts numbering system. They phased out the 5-digit numbers roughly 20 years ago, maybe more than that...many years before the production of this lamp moved to Romania. They went through the effort and expense and agony of changing to longer numbers that weren't the same as the German/most of the world numbers, that lasted a few years, then they migrated to another system of different longer numbers that still weren't the same as the German/most of the world numbers, that lasted a few years, and now they have a system where the US part number consists of
part of the German/world numbers. I have no idea why they do this idiotic dance every few years, somebody must be making money off it. Anyway, while all lamps merchandised as "72207" were made in Germany, there were also plenty of lamps made in Germany and merchandised as "003427291" (and as "E003427291", etc).
what Bosch 200mm headlamp part #s should I be looking at, if at all
The Bosch 200mm headlamps were discontinued quite a few years ago. Part numbers were 0301019100 (no position/"city"/"parking" light -- also sold in Canada by the pair as "SBQ 200") and 0301019101 (with position light). They were a better lamp than the Hella ECE unit, about on a par with the Cibie's performance. Bosch reflector and lens durability were better than Cibie.
the reason I ask is because I found a pair of NOS 722027 German made Hellas (stamped on the lenses)
"Found" like in the basement in good condition? By all means run 'em! But if "Found" means someone's making out like the German manufacture makes it superior to the current Romanian product, and wants a high price? Fuhgettaboutit.
as well as a pair of NOS Bosch
Same thing here. If "found" means you already own them and they're in good condition, go for it. Or if you found a pair for a good price. But if you found a pair priced unrealistically, pass.
(The Bosch large rectangular H4 lamps did not come in separate/different versions for motorcycles and non-motorcycles, hence the large amount of alphanumerics molded into the lenses)
