84W HID Blitz Cannon (Creator: member BVH)
330 yards
See Full Pictures Here...
Dear CPFers, this is one of the most powerful and best throwing Blitz 240's ever created.
Actual input power consumption to the ballast of 114W with 84W actual output to the 100W bulb for around 9000-9500 lumens. It's fairly compact for a spotlight and very usable with the two stage ballast. Should give around an hour at 84W and about 3 hours on low. It's powered by a 6400mAh lithium polymer (li-po) battery and charges off of any hobby charger capable of charging li-ion/li-po batteries. This is a true 1000+ yard light and I was once able to easily walk along a hill side without a flashlight, with my brother shining the light from 925 yards away, on a moonless night. I'm guessing that it would still provide a reasonable amount of light at a mile or 1760 yards.
See more info from BVH's thread here...
This is the most incredible light I've ever owned and I'm passing on the joy to the next lucky owner. The light is basically the same as purchased from BVH but I painted to top cover to the battery box black and made a few slight changes inside the box. It has full battery protection circuits and a fuse which should continue to provide rock solid, trouble free enjoyment for many years. The bulb is probably just barely broken in judging from BVH's and my combined run time. At 2-3A charge rates, this battery should provide 400-500 full cycles and has probably seen less than 10-12 cycles thus far. You may also charge this battery at up to 6.4A if you're in a hurry but can it will slightly reduce the number of charge cycles. There is a lot of build detail and thought that went into this light and anyone who realizes how BVH is about his projects knows what I'm talking about. Remember, he's our resident 60" Carbon Arc Professor.
If you'd like additional info or pictures of anything specific I can do so, but please read the other links first. :)
Some more of BVH's beamshots comparing the touted 75W Barn Burner. (Keep in mind that BVH's Barn Burner is tweaked to 80W)
The Price is $800 Now $760 Now $740 which includes PP and ground shipping. Tracking and Insurance will be an additional $15. Conus only please.
First "I'll take it" will get the light and Payment should be made within 24 hours of your post. Thanks for looking and good luck! :wave:
330 yards
