8AA charging options - pack charger or dedicated charger?
KevinL
At World's End
My TK40 demands 8 cells at one go and I like to drive it in Turbo mode, which means recharging more often ;)
I have a variety of decent chargers at my disposal, so was wondering whether I should pony up for a 8-bay or re-use some of the options.
1. Use the Energizer 15-minute AA charger with Eneloops. I wonder whether this method is too abusive - I like the 15 min charge, but it always leaves the cells hot, and while it has been 'ok' over the years I have always wondered in the back of my mind what are the implications.
2. Charge the 8 AA's in their carrier on my Hyperion EOS 5i pack charger. This charger/analyzer does everything I care to throw at it. Only downside I can think of is that the cells aren't individually charged and balanced. Also I can't do this with mismatched groups of cells - I sometimes need to charge 8AA's (2 sets of 4) for my camera flashguns.
3. Pay up and buy 8-bay charger:
http://www.mahaenergy.com/store/viewItem.asp?idProduct=422
The thing about charging batteries is the hassle. I would rather set-and-forget something and let it go till it's done. 2 hours is an acceptable charge time, but wouldn't want longer than that.
Opinions welcome!
How about using your Hyperion for day-to-day charging, and purchase a Maha C-9000 to have a closer look at individual cells every thirty days or so? I like the 801/808, but they tell you nothing of the individual cells health. I think those would best be paired with a C-9000.
I would swap over to a 2x18650 powered quad-die platform. You could probably sell your light, collection of eneloops, chargers, etc, and have plenty left over to get a top notch 2x18650 powered light and Pila IBC and cells. cell handling would be dramatically simplified, runtime would be about the same, body diameter would be far more graspable....
I plan to see how it goes with a single C-9000 and 16 Eneloops dedicated to the light. The first week with the TK might require more than normal charge cycles - we'll see ;)
Hi Kevin,
For me, the whole point of buying a mid to upper range charger is that it can do nearly any charge job for you and reasonably well. I avoided using R cells until I could really justify a decent charger that could charge pretty much anything I had or planned to have, including tools.
I seriously considered the Hyperion when I picked up the Triton II - it was a close match, with each able to do some applications slightly better than the other. My decision ended up being made on its ability to charge a 28V SLA hedge trimmer. :)
I would just charge the TK 40 8 pack in the hyperion in series, but at a bit lower rate - maybe .2 - .4 C, then let it go into a trickle. It is unlikely that your cells are really full discharged each time, so it does not take that long.
I put letters on each of my cell "sets" (A, B, C) and try to keep them as 4 each sets. This is a handy size for most R uses that we have and an easy setup to charge (in series) In limited use applications, I just use the Energizer Li AAs for everything. Another option to reduce "flash" cell use is - try using available light photography. I hardly ever use a flash anymore, but perhaps your needs are more serious than mine.
Most NiMHs will tend to self balance if given some extra time on a series charge, so balancing is not as big of a deal. I did find that I had to adjust the dv/dt default setting on the Triton for slow charging NiMHs for it to terminate properly - no idea on the hyperion. I have played with parallel charging, but the Triton maxes out around 10 AH IIRC, so I had to reset it sometimes for 5 AH sub Cs.
It is not so easy to really achieve perfect balance in NiMH cells anyway, whether charged in series or parallel. I have some 6S r/c NiMH packs that run "2 in series" on the car, but are easier for me to charge one at a time. There is almost no chance that the two packs will ever have an exactly balanced charge to each other, as the first one self discharges a bit even while the second is charging anyway.
Cool, thanks for the tip.
I've never run out of AA battery power for the flash while on location, but that's probably because I am not the gung ho blasting flash all over the place with no understanding of light behavior or power control and a $100 fancy diffuser (which only serves to rob power) stuck on the flash. If you shoot events PJ or press style, you need the flash. I find myself stuck in many a pitch dark situation too, where even the Canon 35/1.4 isn't enough..
However I do carry lots of spares and making sure the non-Eneloop cells are topped off is a hassle. Slowly phasing them out - maybe I should 'faster phase them out' :D
I suppose I am really trying to justify the 8-bay charger :)
I'd stick with the hyperion series charge. They'll stay pretty well balanced with that method.
