Finally, I crack my 9 Volt battereys. It was not to hard to open them even without "cosmetical" damages. Exept Tenergy (blue) , but it was dead any way, and Tenergy centura (white) - I did not open, because it new, in good condition. Both Tenergy in Thermal Shrink Tube. Rest battareys MAHA, and chineese (BTY,GTL) in plastic case with stickers. Very ease open without damages!
What I see inside? Blue Tenergy 250mAh has 7 "discus"(button) Ni-Cd cells - worst! This kind of cells absolutely NOT overchaarge protected. It is older type of accumulators - ease overheating and pops! (0.2C-maximum charge current).
On picture one cell is popped, another - leaked...
Chineese are much better. Using seven cylyndrical 10x15mm probably Ni-Mh cells is uncommon shape, shorter then 10180. may be special size to fit to 9V battery.
Cells without any marking (it is normal...) GTL even has self curing (polymer) fuse LV175 (4A), but fuse is useless, because trash chinees cells can not give more than 100-200mA...
MAHA Imedion 250 mAh(low self discharge???) has 7 rectangular 5x14x22mm cells probably Ni-Mh
Conclusion:
Voltage.
All batt. has 7 Ni cells 8.4 Volts
Only MAHA Imedion marked 8.4V rest battereys 9V - Not big difference nominal/maximal voltage.
Capacity.
I have not enouh time to mesure real capacity, need very low discharge current (around 10mA) but I think all have simillar low capacity around 200 mAh (exept GTL with very low quality cells BUT WITH VERY LOW SELF DISCARGE.... strange, but real!) May be I will mesure mAh later...
Internal Resistanse.
Tenergy (blue) - >2 Ohm per cell >14 Ohm on battery - GARBAGE!
Tenergy (white)- ~70 mOhm p/c ---- 775 mOhm - PERFECT!
MAHA (black)- ~180 mOhm p/c ----- 1.2 Ohm - NORMAL
BTY - ~70 mOhm p/c -------------- 0.5 Ohm - PERFECT!!! (2 for $5)
GTL - 180-250 mOhm p/c ---------- 1.4 Ohm - NORMAL
Self Discharge.
Tenergy (blue) - 100% for couple months - Unacceptable!
Tenergy (white)- low (LSD)
MAHA -low (LSD)
GTL - LOW (cheap chineese)
BTW - I do not know - new battery...
(I do not measure Self Discharge, evaluate by using battereys inside DMM for long period of time - more then 6 months)
