9006 low beam upgrades
jasonsmaglites
my parents have a 97 suburban and the headlights are just plain sad. i bought one hir 9012 to upgrade the 9006 low beams and am not very happy with the results. the 9005 high beams are still much much brighter. what have you guys done to upgrade 9006 low beams and still get a good light focus and beam pattern?
Your best bet with that truck will be completely replacing the grill and headlights. The work truck grills use 6.5" by 8" sealed beams, and some very good quality Euro-beam replacements are available in that size. GE Nighthawk sealed beams are supposed to be pretty decent as well.
Edit: That body style Suburban shares front ends with the C/K trucks, Suburbans, Tahoe, Blazer, of both Chevy and GMC. There have been umpteen different options using a couple different kinds of sealed beams(which mostly suck), composite headlights(which, for this truck, all suck), and a massive aftermarket presence(All of which is garbage - all). Lots of grills available from scrap yards and the aftermarket. The work truck grill and the sealed beams I mention above is your best bang:buck ratio.
Subcribed... I have an 04 Jeep Liberty with ****-poor headlights also. No, there's no money to do a whole grille job.... I'd love to find drop-in replacements also, or find a compatible headlight housing/assembly with good optics.
Rich
diesel bomber, i'd be open to that option. what models and years am i looking for? got a pic or a link so i can understand exactly what youre talking about. what low beam bulb do they use?
Lookup starrhid.com...they might have something that fits. (They make a whole headlight assembly for the 1997 year pick-up truck...I think it will fit the same year Suburban as well.)
The other replies you're getting here are right; the aero headlamps are hopeless junk. No bulb swap will fix them; they're cheap and nasty and produce sloppy, unfocused beam patterns with a bunch of glare. Also they lack a bulb shield, so that HIR2 swap you did is creating a ton of backscatter in bad weather and glare all the time, no matter how you've got them aimed). All of the same size/shape aftermarket replacements, whether they look just like the originals or are differently styled (halo rings, projectors, clear-lens/faceted-reflector, etc.) are even worse junk than the originals. There is a European-code version of this headlamp that's not too bad, but also not too good. It's made by Arteb of Brazil and is very difficult to get in North America. The only reason I know of its existence is that Dan Stern had a pair (or maybe just one side, don't remember -- also had the cool E-code 3-color taillights for the '87-'97 Chevy truck) in his collection when I toured it some years ago.
The swap in question may sound like a lot of work, but it really is your only way to get decent headlighting on a truck of that make and model, and it isn't too difficult. You'll wind up with a setup that looks like this. The grill is available with either a GMC logo or with the Chevrolet bowtie. It is available unpainted (grey plastic), painted body color, chromed, etc. There are different versions of it so you can probably find one that looks OK to you.
I like this online wrecking yard inventory search tool. You can narrow the search down by area or state, results are based on reliable Hollander interchange information, and in general it's quite a good tool. I would search on 1997 Chevrolet Suburban 1500, then grill, then on the next screen pick the "Sealed beam" option. Search results are sorted by price from high to low. Take your time, browse through the results and find something nice. The ones listed as "New" will be aftermarket items of poorer quality than original equipment. Try to find something listed as complete with lights so you'll get the turn signals and such. Note you will also need the left and right headlight "buckets" (brackets with aim adjustor screws) so try for something that hasn't been steeping in salt for fifteen years, go for parts from a state with a nice climate.
This swap puts standard-size headlamps on the truck, so you have a lot of options in what to run. Selection is pretty easy. If you need to keep it cheap, the only ones to get are the GE Night Hawk sealed beams. If you want replaceable-bulb halogen, get Cibiés. If you have a fat wallet and want ultra-premium, your two options are the StarrHID Xenon items made by Giant-Lite of Taiwan, or the JW Speaker Model 8900 full-LED lamps, which I prefer (roughly equal performance, better materials and build quality, made in America, less dippy appearance -- that last one's an opinion, the rest are facts).
You will have to make some wiring modifications whatever headlight units you use. If absolutely nothing else you'll need to adapt the existing 2-bulbs-per-side headlight sockets to a single 3-prong standard H4/sealed-beam connector. If you stick with halogen, put in relays. If you install relays or run the HID or LED options you'll need to disable the truck's daytime running light circuit (if you want or need DRLs, put in a turn signal DRL module).
Rich
Don't the Liberty's have 7" round lenses? Either Dan Stern or rallylights.com can fix you up with a new bypass harness and new lens w/good bulbs...
The first-generation Liberty headlamps are dreadfully bad. The facelifted Liberty (2005-07) got new optics. They're still not the world's finest headlamps, but considerably more efficient than the pathetic pre-facelift ones, and they are physically interchangeable. Be sure to get real Chrysler ones; the aftermarket items give poor performance and durability. Use www.realmopar.com or another of the online Chrysler parts discounters to get them at a good price. Put in Philips Xtreme Power 9007XP or GE Night Hawk Platinum 9007NHP bulbs. Aim them carefully.
anyone know of a decent, name brand, slightly higher wattage bulb. i dont want to go to 100 watt. is there anything in between stock and super high wattage. my parents dont want a grill change and the hir9012 i got from amazon didn't work well.
A high-watt bulb will not make the headlamps work well -- it will in fact worsen their performance and make them dangerous for awhile until it melts them. If your parents do not wish to do the only modification that will allow them to see well at night, then they (and you) are stuck with the truck's headlighting performance at it currently is with a 9006 bulb. High-watt bulbs are also illegal, and Rule 11 of this board prohibits advocating illegal/dangerous lighting modifications.
Um…no. This is even more dangerous than a high-watt 9006 or a 9012 swap into those headlamps. Dangerous and illegal levels of glare no matter how the lamps are aimed, and impossibly high (and illegal) levels of uncontrolled upward light causing backglare in rain, fog, or snow. It sounds as if you have the idea to improve your parents' safety at night, but these ill-advised and illegal modifications you're making are only going to worsen it. Stop it now, please, but even if you press ahead, you need to stop discussing them here. Last warning.
One of my neighbors has a Chevy pickup with that body style. We retrofitted Hella 60mm modules in place of the headlights. Didn't take long, looks a little odd, 100% legal and very effective. If you have a bit of fabrication skills, you could do the same without too much trouble.
Diesel_Bomber's got a very good idea. Hella 60mm or 50mm modules would be pretty easy to retrofit and would give a very much better and safer result than horsing around putting the wrong bulbs in the original headlamps.
the hella mod sounds the best idea to me, as putting wrong bulbs into oem headlights. little story from personal experience when i was younger i had a beater car that i use off road for a toy. and put the wrong bulbs in and the headlamp caught on fire and proceeded to burn till the bulbs blew and it went dark then i proceeded to roll the car over two or three times after hitting a bank i could not see!
Do you have a picture of that?
Bet it looks pretty odd...
