Hello Gopurple,
I must confess that one of my immediate goals is to learn how to read, and to comprehend what I have read...
For some reason I was convinced that the voltages and ZTS readings you were giving were for fully charged batteries. I was wondering, in your last post, what charger offered a high setting...
I am not sure post #2 even registered with me...
Sorry for my confusion...
Now, having taken the proper time to read and understand your tests, let me see if I can make a helpful contribution to this thread...
I believe the PAK-Lite is direct drive, so the highest voltage under load would yield the brightest beam. Even though your 230 mAh battery rebounded to a higher voltage, the 300 mAh battery probably had a higher voltage under load.
Is there a way for you to measure the voltage of the battery while the light is running?
The 9 volt batteries are made up of 7 cells in series. The 9.6 volt batteries have 8 cells. In order to get the package the same size, the 9.6 cells are smaller and have less capacity. The trade off is that the 9.6 volt battery is suppose to offer a higher voltage.
Another factor with the performance of these batteries has to do with charging. A charger designed for the 9 volt (7 cells in series) battery, may not be able to fully charge the 9.6 volt (8 cells in series) battery. You can check your charger by measuring the voltage at the end of the charge. The 9 volt battery should end up at around 9.8 volts, while the 9.6 volt battery should be at around 11.2 volts.
I don't know which was used for the ZTS tester, but I may venture a guess that its calculations are based on a 9 volt NiMh battery.
At any rate, 10 hours of run time on high seems good.
My limited experience with these batteries has found that the 9.6 volt battery tends to have a slight larger size, and these batteries don't always fit. The 9 volt battery packaging seems to be more robust, and the size seems to fit most applications.
I have been checking on the self discharge rate of 9 volt batteries. So far, it does not seem to be all that high, but it is still early in the testing. I have been "playing" with Titanium 9 and 9.6 volt batteries, but I am not sure you can directly compare them to the Powerex batteries.
Tom
