Hello Johns,
The major problem with 9V rechargeable batteries is that often the cells get out of balance. In addition, they are not fast movers, so the chance of getting batteries that have been sitting for an extended period of time on the shelf is high.
The best thing to do is to measure the batteries before you charge them. A 7 cell battery (8.4 volt) should have a voltage above 6.5 volts. If it is below 6 volts when you first get it, you may have your work cut out for you trying to bring it back to life.
Also, most of the chargers are designed for the 8.4 volt batteries. If you try to charge a 9.6 volt battery on them, you will not end up with a full charge and will experience short run times. Keep in mind that the 9.6 volt batteries are generally larger in size and may not fit in some devices.
The best bet may be to go with the 7 cell battery and hope you get a decent battery to start with.
Tom
