Robocop
Mammoth Killer
I am tinkering around with a standard 9volt battery and two 5mm LEDs from keychain lights. I can not find the information searching old threads on this mod and am hoping someone can help me now. I am trying to make something similiar to the pak-lite using two 5mm LEDs for long runtime off of the 9volt cell.
I have various resistors and need to know first should I wire the LEDs in series or parallel and can I use one simple resistor between the positive supply and positive lead of the LED? I would also like to know the value of the resistor to obtain something close to 25mA for decent runtime. The 5mm LEDs are all salvaged from various keychain lights and I assume they should all be pretty close in vf and specs.
I have several small smd resistors however do not know how to figure the formula to calculate the resistor....however I do pretty much know how to read the numbers on the smd resistors.
Seems like a pretty easy and fun mod for a long running night light and I have plenty of 5 mm LEDs and a few of the 9volt connectors. Thanks for any help on this.
