Parallel LED Current Balance Circuit and Resettable Breakers
hmm, nice!
if you really want simple/cheap you could always set in a resettable breaker
I have a couple Raychem "Polyswitch" # RXE-065S-1 circuit protectors...they look like ceramic disk caps, constant current around 600ma...it'll trip when I run over 1200ma through them then reset when I turn the power off.
Resettable Breakers
I have a 60V 11A adjustable Power Supply and wanted to safeguard against someone adjusting to 11A and blowing up Current Balancing Transistors or LED's.
Anybody using these Polyswitches, do you have a known Source Current reference to give some real world experience.
A device like
RXE-065S1 would be perfect If the trip Current stayed within the 1.3 to 1.053 Amp variation (20 to 40C).
But when the Data sheet mentions Min Hold Current is 0.65A and Max Trip Current is 1.3A there is a very large gap between.
So the question is, how tight is the Trip Current in real use.
I will have to buy some and check, but welcome any hands on experience!
Thermal Derating Curve
You will see below the
Raychem RXE-065S1 trigger current changes 19% between 20 and 40C Ambient Temperatures.
The
Littlefuse RKEF065 has very similar specs with
tighter trigger Current variation of 13% over 20 to 40C Ambient Temperatures.
Time-to-trip
The other thing is time to trip in seconds, the
RXE-065S1 is more like a
Slow Burn Fuse at 5.3 Sec.
Which makes me think this might not be suitable for my purpose, but would protect from a slowly rising current?
The
RKEF065 has a faster,
1 second trip time.
But would it trip before damage if someone dialed up the current on Power Supply.
Anybody know?
Here's some Specs for those who are interested, 40C Trip Currents are derived from graph - double check with data sheets before use.
RXE-065S1 60V - Raychem
% of rated hold and trip current for Ambient Tempretures.
Thermal Derating Curve (81% of hold and trip @40C)
Hold Current (A) 0.65 @20C
Hold Current (A) 0.47 @40C
Trip Current (A) 1.3 @20C
Trip Current (A) 1.053 @40C
Time-to-trip 5.3 Sec
Time-to-trip with Fault Current of 10A = .1 Sec
Min Resistance 0.31 Ohm
Max Resistance 0.48 Ohm
RKEF065 60V - TE Connectivity or Littlefuse
Thermal Derating Curve (87% of hold and trip @40C)
Hold Current (A) 0.54 @40C
Trip Current (A) 1.30 @20C
Trip Current (A) 1.131 @40C
Time-to-trip 1.0 Sec
Time-to-trip with Fault Current of 10A = .09 Sec
Min Resistance 0.250 Ohm
Max Resistance 0.450 Ohm
RKEF050 60V - TE Connectivity or Littlefuse
Hold Current (A) 0.50 @20C
Hold Current (A) 0.38 @40C
Trip Current (A) 1.00 @20C
Trip Current (A) 0.87 @40C
Time-to-trip 0.8 Sec
Time-to-trip with Fault Current of 10A = .06 Sec
Min Resistance 0.320 Ohm
Max Resistance 0.529 Ohm
