Re: Want to post some runtime graphs
About 35 hours on the TLE-1F till it takes the "big plunge".
The Nite Ize 10mm did about 90 hours till "the big plunge".
A rough guesstimate says that the TLE-1F draws about 3 times the current of the 10mm?
So... is the TLE-1F that much brighter than the 10mm Nite Ize?
How bright does it seem to you - as compared to other lights?
Does this module get very hot to the touch?
It's going to be interesting to see if the Nite ize "TLE-1F clone" has the same run time characteristics! :popcorn: I'm betting it is the exact same module!
Cydonia,
The Terralux TLE-1F seems about twice as bright as the Niteize 10mm. The data show this as well (200Lux vs 920Lux). As far as heat, after 5-10 min I could hold my finger on the Terralux and it was barely warm.
Looking at the graphs I have made the following observations:
The MagLED module makes about 4650 Lux then quickly drops to about 2500 Lux in half an hour. After 8.5 hours at 2500 Lux it starts to drop off slowly and it takes 42.75 total hours to reach 1000 Lux from the start of the test.
The Nite-Ize 10mm bulb starts at 1875 Lux then drops to 1000 Lux in 6.5 hours.
The Terralux starts at 2400 Lux then drops to 1000 Lux in about 37 hours.
The 10mm drop-in will have light for a longer time since it is just slowly dimming after some rediculous amount of time but for usable light it seems that the MagLED is the one to get. Add to this that you can change the emitter fairly easily for an SSC P4, which will just about double the output from this drop-in and it seems like the logical choice.
I'd love to see the three graphs (plus the remaining Nite-Ize drop-in) on one graph as a comparison.
Having said all that I'm probably getting the Nite-Ize 1W drop-in for one of my MagLites.
PCC,
Not sure about your numbers on the Niteize 10mm. It starts at 920Lux, drops to 900Lux in 32hrs, 800Lux at 70hrs and then falls off at 92hrs.
As far as the Mag LED being the one to get, I'm betting the Niteize 1W is going to beat it. It's been running for 24hrs and is still putting out over 2800Lux. It'll be interesting to see how long it will run.
big waffles, can we get a graph of all the d size dropins together so we can more directly compare. thanks for turning us on to the 1watt terralux. i had no idea is was such a good lumens to runtime deal.
PCC/Jasonmaglites,
Yes, when the Niteize 1W finishes I'll post that graph as well as a compilation of all the 3D Mag drop-ins that i've tested. I'll put it in the same format as the Mini-Mag compilation graph.
So far here is how I rate the beams (subjective, I know):
Mag LED - Brightest and harshest. This has the whitest/harshest beam and is very good for illumination. Few shadows.
Terralux TLE-1F - Not as white as the Mag LED. Seemed a bit yellower/softer. Good illumination.
Niteze 10mm - Blue, almost to purple, lots of shadows. Good for around the house. Makes a good tailcap backup.
More to follow.
C.P.T.
