lunas
- Joined
- Apr 18, 2014
- Messages
- 206
So you filled the cup with water till the top?
do you think the wire is better than alligator clips?
When you did the touchup with the tap water, did the color come out the same as with the borax?
just below the top enough to cover the piece to be anodized without touching the coil i would recommend using a bigger cup and keeping the distance equal across the whole piece im guessing that is the reason for the color gradient i got on my light vs the skull piece
i would use the alligator clips going from the batteries to the wire and still use wire going from the piece to be anodized.
and the touch up the spots i touched with the tap water turned the same color as the surrounding metal. The color you get from this is voltage dependent so if your going for the color 27 volts gives it will be the same color i suppose if you left it sit for long enough at a given voltage it should slowly grow thicker through the full spectrum of color.
The higher the voltage the thicker the anodized layer and the thicker it is changes how it refracts the light.
In the end i would say what substance you use does not really matter as long as it conducts electricity for the electrolysis by using water and borax i ended up with a solution i could watch the piece change color i know the main complaint about using pepsi or coke is you cant see the color change while it is going on.
