Barbarin
Here you are, one of the most important buildings in my hometown. It had in the past 3000 Watt of incand lighting. Now it is 176 Watt/hour.
The whole idea was to light the arms coming from the columns, they suggest the force and strenght of the building. I wanted to make them look dramatic, with bright areas and dark shadows, making the arms look deeper, stronger... and all this while trying to keep the column as dar as possible. The only place in which was possible to anchor the spotlights was in the column itself. It has 4 IP68 spotlights, with 4x CREE XRE driven at 1 Watt each.
Hope you like it.
Hope you like it.
