A problem with a flashlight
uiko_09
I got a LED flash light from a friend.
I don't know what model is, everything I know is that on it I can read 99701.
Where can I buy a LED for it ?
Thank you
Welcome to CPF, uiko. For someone to be able to help we need more information. Do you want to use a brighter LED or does the one in the light not work? If it doesn't work, first try cleaning all the contact points. This is usually the cause of a non-working LED flashlight. Just get a cotton swab with some alcohol and go at it. Even a pencil eraser will take the corrosion off the electrical contacts. Good luck.
Geoff
Can you get a picture of it?
Is it a 3 AAA multi 5mm LED light?
High power LED light? (if high power LED, can you get a picture of it)
What would you like to do with it?
:welcome:
