A19 CREE(1x123) two-stage 5ohm runtime in low
Manzerick
Boston, Massachusetts
Hey Folks,
I just moded the tail cap of my A19 and was wondering if anyone had an idea of the runtime on low with a RCR123a and a CR123a?
Thank You!
I just tested mine and low is the same as the lowest setting on a U2..
Does that seem that same as you saw Beamhead?
Beamhead said:
Mine put out very little light at 5ohms, I am at 1.5ohms now and happy.
I have no U2, but with the 5ohm I would guesstimate 10-15% and with the 1.5 ohm 40-50% of full brightness.
HTH
That makes sense!!
Thank you sir! I can assume that at 10% it wil run for a minimum of 200 minutes (conservative)
Thanks again Beamhead!!!
HTH
When you add the mc2es switch to your A19-XRE, does the light then function like Surefire's A2? In other words, do you now have the ability to push lightly for momentary low, or more for momentary high, and also to twist for constant low/constant high?
If so, I definitely need to mod my A19-XRE this way.
Thanks in advance for the help!
- FITP
That would be correct FITP...
I dont know if you have the 1.5 body, but you should get that too. Gives you longer runtime. A19's are my favorite light as of now!
Iceman
I don't have it....well... yet LOL
That works with like the 14500, right?
Are they at the Shoppe? Cost?
TY!
Iceman
Thats right! I didnt know they only have it on black; I have both Bodies and the 1.5 black body doesnt look bad at all even if you have the HA A19 head. IMO, I like that contrast in color. I thought the 1.5 body is long. but its just perfect for edc with great runtime on the 17500 cell.:)
