357mag1
Below I've listed tailcap current readings taken from the Nitecore D10 Tribute and a Romisen RC-29 II Q5 with various AA size batteries. All readings were taken with two Fluke DMMs (older 87 for current and new 77 Ver IV for voltage)
Somebody smarter on flashlights circuitry than I may know what type of regulation (if any) the RC-29 uses. It draws an amazing amount of current.
RC-29 results:
Eneloop charged 1 month ago - 2.3A at 1.25V
Eneloop fresh off charger - 2.98A at 1.35V
Rayovac 4.0 charged 1 month ago - 2.23A at 1.19V
Rayovac 4.0 fresh off charger - 2.67A at 1.3V
Nizn used several times in tooth brush and at 1.74V static - 4.2A at 1.6V
Nizn fresh off charger - 4.6A at 1.7V
Energizer Lithium fresh - 2.4A at 1.3V
Energizer Lithium 60 seconds of use - 2A at 1.25V (continues to drop off fairly fast)
Mastercell Alkaline (made in China) - 2A at 1.18V
Mastercell Alkaline after 60 seconds - 1.86A at 1.15V
D10 results:
Nizn used in RC-29 for 17 minutes - 2.2A at 1.6V
Nizn fresh off charger - 2.15A at 1.75V
Eneloop (charged in the last 12 hours) - 2.65A at 1.3V
Rayovac 4.0 (charged in the last 12 hours) - 2.99A at 1.18V
Energizer Lithium (New from different pack) - 2.9A at 1.16V
Mastercell Alkaline - 2.6A at 1.116V
14500 AW (3.7V) Unprotected - 1.05A at 3.97V
14500 AW (3.7V) Protected - 1.08A at 4V
I've seen the Energizer Lithiums last almost 3 hours at a 1A draw but they don't seem to hold up well under these higher current conditions. The Alkaline looks good but after about 3-5 minutes it is headed downhill fast. I was amazed at the Nizn current draw in the RC-29 and let it tail stand for 17 minutes while inputting this information. The light got fairly warm (like a good hand warmer) but started to cool down shortly after closed my hand around it. I wonder if the tailcap has enough resistance to lower the current draw some?
The Eneloops continue to prove their worth with the only sensible option being the Nizn (my opinion) if you want or need greater voltage.
Until I conducted this little test I had no idea these little batteries could substain this type of current output. No wonder 4 Duraloops have no problem powering my TK40s on Turbo.
I decided to take the Energizer Lithium used in the D10 test and see how long it would last in the RC-29. The way current and voltage seemed to be dropping I thought it might not last long. I have left the light on and tailstanding for over an hour now except to cut it off and measure current at 15min (2.1A) and 30min (2.1A) and 52min (2.04A) and 68min (1.89A). It is presently at 1hr 15mins and seems to be going strong. Very little loss in output. Guess them Lithiums are doing okay after all. I'm sure any Alkaline would have been long dead and the rechargeables would need a refresh charge by now.
RC-29 results:
D10 results:
