In this thread: my 2011 shootout between 4 different models of rechargeable AA NiMH batteries. The contenders are:
The batteries were donated for independent testing by Steve at www.electronicswarehouse.com.au (Vapex & Eneloop) and from Jeff at www.protog.com.au (Imedion and Powerex).
I have a wide range of tests scheduled to test various properties of these batteries, including capacity, variance, self discharge, high load, camera flash cycle times, high cycles, cold temps, and if the memory effect is a myth or not. I will be updating this thread with results as they come in. When I get bored I will do repeated long term self discharge tests (eg 6-12 months).
Notes:
- 4 x Vapex Instant 2500
- 4 x Eneloop (the newer 1500 cycle ones)
- 4 x Imedion 2400
- 4 x Powerex 2700
Notes:
- All charging and capacity checks will be done on a Maha C9000 charger (Model 0J0CA).
- The cells have been labelled VAP1-VAP4, ENE1-ENE4, IME1-IME4, and POW1-POW4.
- In general, VAP1, ENE1, IME1, and POW1 will only be used in slot 1 of the charger, VAP2, ENE2, IME2, and POW2 will only be used in slot 2 of the charger and so on.
- After charging, cells will be left in the C9000 for at least 2 hours after "DONE" appears for the 2 hour 100mA top up charge.
