So I came across the EDC blog, and it has prevented me from being productive for 3 days now. I came on here, and holy crap are you guys serious about your torches. Anyway, I figure I need to get me a light to EDC - but there are so so many that I can't even bring myself to do the required research! I was hoping I could just ask you guys for a suggestion, since you guys could help me quickly narrow my choices.
-I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
-Preferably closer to $25, but up to $50 if necessary.
4) Flashlight-specific format/size:
-Keychain size - or possibly a small EDC size
5) Emitter/Light source:
-LED, obviously
6) Manufacturer:
-I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
-AAA batteries. Regular or rechargeables? Either way, but no buttons or fancy built-in batteries.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
-However much light AAA lights put out? Just around the house, walking around downtown, that sorta thing - I imagine that these lights are gonna impress me anyway.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
-Around the house, close up, walking around downtown (>1yard to 20 yards?)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
-I have no idea how long these are capable of running - again, I imagine that however long this type of light tends to run is going to be plenty.
-Very durable - attached to keys, throw around in backpacks, usual EDC rough-housing.
12) Switch Type and location (choose all that apply):
-I have no idea for this one. Suggestions? If I'm guessing correctly, 'forward clicky' is the light activates when you push the button, and 'reverse clicky' is the light doesn't activate until you release the button?
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
-Multiple output levels would be neato, but not necessary. I don't know what these are: programmable, selector ring, SOS mode, beacon mode. I'm guessing those features are gonna be too fancy for my price point anyway.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don't care.
____I don't know.
14)Material/Finish/Coating
-Aluminum? Whatever is cheap, lightweight, and durable enough.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
-Ability to attach to keychain. I might use a pocket clip - but I would want to be able to detach and reattach it if I change my mind (even if I have to remove screws or something).
I took down some names that I came across in browsing these forums, in case some of them fit what I need:
4sevens(several), iTP A3 EOS, McGizmo, Zebralight, Streamlight Nano, Streamlight Microstream, Maratac AAA, Fenix (several).
Thanks so much for your time in reading my giant wall of text and helping me narrow my search! I look forward to learning from your collective expertise.
-LED, obviously
6) Manufacturer:
____I don't care.
____I don't know.
