Does anyone know the actual (measured!) diameter of some 17650 or 17670 Li-ion batteries?
The back story is that I have an older flashlight with a 3.6V NiMH battery pack (16.6 mm x 85.1 mm) that need to be replaced. The battery pack is available as a special order item for around $25 + S/H; however, I think I could get a better battery for less money if I replace it with a Li-on battery. (and a conductive spacer to make up for that roughly 20 mm))
One 17670 battery has the diameter listed as 17 +/- 0.5 mm. However, the inside diameter of the battery compartment is only 17.1 mm, meaning that an 17670 with the above tolerance may or may not fit. That's why I'd like to know if someone has some actual, measured data on it. The backup plan would be the 16650.
