DIWdiver
Re: Adjustable 10A linear LED driver - limited quantities
The IS1006 would work as well with incancescent load as with LED, but as Al Combs points out, there are better options for many applications. Incans are very tolerant of high voltage spikes, as long as the average is within reason. That allows a PWM driver like those he suggests to work really well.
LEDs would
under such treatment. They want strictly limited current (which means you can't simply turn a high voltage on and off, like you can with an incan). This is why the IS1006 was developed. But in addressing the limitations of LEDs, it ignores one of the biggest strengths of incans.
Depending on your goals, the IS1006 could be either a clever or very foolish choice for a hotwire. Perhaps if you tell us what attracted you to this driver, we could help you decide which it is for you.
D
Just curious, would it be a bad idea to use one of these in a hotwire mod? Say something like an Mag85?
LEDs would
under such treatment. They want strictly limited current (which means you can't simply turn a high voltage on and off, like you can with an incan). This is why the IS1006 was developed. But in addressing the limitations of LEDs, it ignores one of the biggest strengths of incans.Depending on your goals, the IS1006 could be either a clever or very foolish choice for a hotwire. Perhaps if you tell us what attracted you to this driver, we could help you decide which it is for you.
D
