RickB
AE Light AEX25 25 watt HID "Handheld Searchlight" PRICE DROP 4/18/2021
Hi all, I have an AE Light AEX25 HID "Handheld Searchlight" for sale. I purchased it from a fellow forum member in 2007 and it has sat on the shelf almost unused since then. I need to clear out some space, so I'm putting it up for sale.
The battery took a charge and the light works as expected. As far as I can tell it is in nearly perfect new condition, with maybe about 20 to 30 minutes of runtime, tops. Cosmetically the only thing I can see that's not new looking are the rubber parts, which have a powdery-looking patina. I think some automotive rubber dressing would probably clear that up.
Includes the case, light and battery, A/C charger, carrying strap, lens cloth, manual, and warranty card (everything it's supposed to come with new).
Specifications copied from manufacturer website:
Offering mine for sale for $200 as of 4/18/2021 (was $400), including shipping via USPS Priority or UPS Ground. Payment via PayPal is preferred.
Let me know if I can answer any questions about the light. Thanks for looking!
The light is still offered for sale from AE Light as well as a few online resellers. For more information about the light, see those websites.25W HID Metal Halide
Lumens: 1500±
Projection distance: Up to 3000 ft
Color Temperature: 6500K±
Run time: 120 minutes w/4000mAh battery
Length: 13.5 in., 343mm
Weight: 32oz., 907gm.
Light head: 3 in., 76.2mm
Handgrip: 1.5 in., 38mm
Battery: Rechargeable 4000mAh Lithium Ion,
Power Switch: Push-button on/off
Beam: 12deg. fixed
Rating: IP67 (Water resistant to 2 meters limited duration)
*IP68 (Totally protected against dust and protected against long periods of immersion under pressure). (*With waterproof battery) [ PLEASE NOTE: This light does not include the waterproof battery! ]
Light body: Black hard-anodized aluminum
Charger: 100/240VAC 50/60Hz & Optional DC 12-24VDC w/overcharge protection, LED indicator
