s.duff
- Joined
- Mar 29, 2006
- Messages
- 282
can someone break down the benefits/differences between going with the nexgen, downboy, or wizard le?
Kiessling said:DownBoy is a buck converter and allows greater battery voltage than Vin of the LED ... and is good for 2x123 or 3x123 combos or the like.
NG is a boost converter and requires a battery voltage below the Vin of the LED and is ok for 1x123
Wiz is a buck/boost converter and allows for 1x123 and 2x123 but is a bit less efficient than the above two.
So ... in the end the driver is a result of your desired battery combo while the drive current set with this driver regulates the brightness of the LED.
bernie
