Scottiver
I just recieved in the mail a used Aleph II. I started playing with it and it seemed to work just fine. Then I took the head off and noticed that the light engine seemed a little loose and I found that the whole thing would unscrew from the head. Then I put it back together and screwed the LE back in until it was just snug, but when I went to turn it on it wouldn't work so I unscrewed the LE some and it would work again but with a very ringy beam so I screwed it back in another 1/8 turn and it was "normal" again but the LE is very loose in the head and it even rattles a bit when shaken.
Is any of this normal? I would think that it would be designed to tighten the LE to the reflector instead of just floating on the threads 1/16 of a turn away from not working at all. Any ideas? Thanks
