AMC7135 driver question
greencardigan
Can I PWM the Vdd pins of an AMC7135 type driver board at 800Hz? This is the frequency the D2Flex uses to dim LEDs.
The AMC7135 data sheet doesn't tell me much.
Any reason you wouldn't just use one of the multi-mode boards? I'm guessing it should work since the multi-mode boards use PWM, but I'm not going to guarantee it.. :)
I was going to use a TaskLed D2Flex PWM driver. It has a much better user interface than the cheap multimode drivers.
