amp power out of the streamlight SL20 charger?
MidKnight
those with a streamlight SL20 could u please tell me what the power output is on your charger pack,its 12Volt output, i just need to know the amp
Thanks
If you're talking about the wall adapter it's printed on the back of the adapter. I think it's 400 or 500 mAh. And that adapter is universal for all of the Streamlight rechargeable cradles except the Stinger Fast Charger when it is used with the UltraStinger.
If your reference is to the current output at the charging sleeve, that will vary depending upon the SL20 model that you are charging. The SL20XP will draw 180 mAh, the SL20/SL20X will draw 220 mAh. That's documented in the operating instructions that were packaged with your SL20 product.
Ok, its just i have a homemade one, that outputs 750mAh, so there shouldnt be any problems
