This is a question I've been wanting to ask for some time. I have a powered USB hub that requires an input of 5V @ 3A. The original power supply has stopped working and I'm trying to find an aftermarket replacement. Now obviously, I will need to find one which outputs 5V, but if I get one that is more than 3A, will that be ok? For some reason, I have always held the belief that the supplied amperage only had to be equal or greater than figure required by the device demanding power. Ie, while the voltage is fixed, the device will draw as much current(amps) as it requires as long as it is within the rating of the power supply. Am I correct? I'm looking to get one of those variable voltage power supplies with a current rating of 5 amps.
