With one difference...This time, I didn't hold back...Instead, I instituted a full-on tourture test of a 1W White HD, bin P2K.
I used a similar setup to the 1W R-O supercooling experiment:
The same 35W peltier, dipped in ice water for heat dissipation.
The rig to the left is my LM338-based voltage regulator. This will crank out over 5A, and is adjustable from 1.2V to 10.5V. I have 2 computer power supplies, one for 12V to the peltier, one for 12V to the adjustable "luxeon frying" power supply.
The luxeon is stuck to the cold plate of the peltier using the "sticky" properties of normal silicone heat paste. This is a bare emitter, so the junction-cold plate thermal resistance is about 15C/W. The cold plate is kept at -20C.
This is run through a 1.2 Ohm, (and later, 0.3 Ohm to enter "fry" mode) resistor. I need 0.3 Ohm since 1.2 Ohms only allowed me to crank it up to 2.4A. The luxeon power supply seems to puke out after about 2.4A.
The data/pictures I have are for 400mA, 800mA, 1.6A, and 2.4A. First, projecting on the cieling at those currents through an NX05 optic:
Notice that even at 2.4A, there is still an increase in light output. Also notice something else: at the lower currents, this white had a slightly bluish tint. At extreme current (2.4A), it didn't get angry blue, it got ANGRY GREEN! /ubbthreads/images/graemlins/eek.gif
And the data:
<font class="small">Code:</font><hr /><pre>
Current Vf P Tj (est)
400mA 3.34V 1.34W 0C
800mA 3.59V 2.87W 23C
1.6A 4.04V 6.46W 77C
2.4A 4.52V 10.8W 142C <-- WOW! (Angry Green color)
3A FAIL!!!!!
</pre><hr />
I examined the luxeon after the failure. I noticed a bubble around the negative bond wire. Closer inspection reveals discoloration and what appears to be soot-like deposits on the inner surface of the bubble.
Observe:
It appears the bond wire fused open at this point.
One more luxeon down in the name of science! /ubbthreads/images/graemlins/tongue.gif
And the data:
3A FAIL!!!!!
</pre><hr />
Observe:
