I want to try to build a dive light for spearfishing and I would like to use a reed/mosfet switch. I thought of using 3xXR-E or 1xP7 running of 3-4 D-size NiMh since I can get more time in the water this way instead of using AA-size (and also because I have some great D-sice NiMh's) I just need a good boost driver then if using 3xXR-E in series
However, I am no electric expert and could therefore really use some feedback on my choice of reed contact and mosfet.
Mosfet:
http://elektronik-lavpris.dk/files/sup2/irl530npbf.pdf
N-LogL 100V 17A 79W 0,10R TO220AB
Vgs+/-16V
Vgsth min.1V max.2V
Reed contact: http://elektronik-lavpris.dk/files/sup2/ksk1a66.pdf
SPST 0,5A 10W AW10-20
Glass piece is only 14mm so pretty small
Finally, I have read that I should use a 10K resistor between the gate and source of the mosfet would this do the trick: http://elektronik-lavpris.dk/product_info.php?products_id=83327 or would it be better to use a metalfilm resistor? and why exactly 10K?
Sorry if my questions are stupid - my excuse is that I am still to build my first light
/Magnus
Mosfet:
Vgs+/-16V
Vgsth min.1V max.2V
/Magnus
