What is the difference between the the 100 Lumens on a
Jetbeam RRT-1 and the 109 Lumens on the Fenix E20? :thinking:
They are 2 very different lights.
The E-20 is an 2x AA-alkaline powered light. It has a 25mm head, is a single mode output light, and has an adjustable beam (spot to flood).
The Raptor RRT-1 is a 2x CR123, 2x RCR123, 1x18650 powered light. It has a large 55 mm head, has 3 brightness modes plus tactical strobe and standby, and is a designed to concentrate the light into the hotspot making it a pure thrower.
The RRT-1 claims to have an adjustable beam, but all it really is tuning the reflector to adjust the hotspot of the beam - a minor adjustment. The RRT-1 also has a head that is not removable.
The more important question is "what do you want to use the light for". If you want an all purpose light, the E-20 would be the better of the 2 (but IMO there are better choices, including lights with a lower low - but at the cost of not having an adjustable beam). If you want a light for distance spotting (deer spotting is the only application that comes to mind), the RRT-1 would be a better light.
The difference is ground breaking. Prices wise, on the paper, 'real life' actual performance and built quality.What is the difference between the the 100 Lumens on a
But for non-flashaholics, i recommend the E20 over the RRT-1 due to various logistics reasons. I don't want to be held accountable over the net when I see on the news:
:crackup:"non-flashaholic blew him/herself in the face when handling high powered battery cells" haha
