any 17670 batteries that output more than 3.7 volts?
ro2themax
is there any 17670 batteries that have an output more than 3.7 volts or any cre123 for that matter? im trying to get the most out of my light (solarforce). thanks
The li-ions actually deliver around 4.2v when fresh from charger while the primaries up to 3.20v sometimes.
What is the voltage rate of your LED drop-in?
If you need more voltage than what a 17670 (3.7V) can give you, you can try 2x Lithium primaries for 6V (~6.2V peak) or 2x RCR123a for 7.4V nominal (8.4V peak)
