flashburn72
I have a house that has a walkout basement. There is a woodburner downstairs with a woodburner directly above on the 1st floor. both burners are hooked into the outside brick chimney by stove pipe. both stoves have the same basic pipe attachments to the brick chimney(3ft of pipe with two 45 bends in them). I have tried to figure it out but for some reason I cant get a good draw on the upstairs woodburner.anytime the doors open the smoke stops going up the chimney and floods the house with smoke. somebody told me since the basement it not heated all the time that the cold air downstairs pressure is differnt from the warm air in the chimney or upstairs and will cause the column of hot air to collapse onto itself causing the flood of smoke when I open the doors. Is there any truth to this or does anybody have any other idea's? could it just be the design of the wood burner? am I not getting the chimney hot enough? I am trying to cut down on the wood smell but fear it is gonna be the nature of the beast.
