I use my M30 in an Aleph 1X123 body, brass E2C adapter, McTc tailcap, with a McE2s switch and Surefire 6p bezel. With my tailcap screwed all the way in it with an AW RCR123 battery it consistently will stay lit for between 25-30 minutes and is brighter than my M60 in a 6p using two RCR 123's or two primaries. Using rechargeable batteries it cuts off immediately once it reaches the batteries protection circuit threshold. With primaries it just gradually gets dimmer in what is called moon mode then eventually quits. I have a 60 ohm resistor in the switch so that when the switch is partially depressed or partially screwed in the current flows through the resistor. using it this way had the light on for well over 2 hours on rechargeable, thats just a guess because I have never timed it, I always change battery before protection circuit in battery shuts it down. One advantage to two stage switch is that when the batteries protection circuit kicks in on high you can back it off and the light will stay lit for awhile on low. This is due to voltage sag when drawing the higher current. I am new to this flashlight hobby and there are a lot of people who could answer you better than I, but this is my experience. I hope this helps.
