Anybody ever get a defective Luxeon?
Sway
North Carolina
Hi Gang,
I was wondering if anybody has received a dead LuxIII right out of the reel. I had 10 TWOJ's that I received several moths ago I had used 2 of them in Mag mods and they are working fine, I mounted 2 more on D O-Sinks for later use.
Well this weekend I build a new C size light and nothing so I pulled the emitter out and AA another in and nothing. I checked the 2 on the D size O-sinks by direct driving them with 3 Alkaline AA's and nothing.
I checked the other 4 emitters and nothing not a glimmer of light, so I'm thinking this is rather odd I thought Lumileds checked every emitter for binning and QC.
Has anybody else come across a group of defective Luxeons?
Later
Kelly
Sway
North Carolina
Ok write this one up as bumbling ignorance I recently picked up some short pieces of Cat5 wire from a free source and made small test leads for LED's and also used on the Mod I was trying to make guess what if you wiggle the wire around it works…..It has broken points all through it /ubbthreads/images/graemlins/smoker5.gif nothing is ever free /ubbthreads/images/graemlins/jpshakehead.gif
Later
Kelly
tvodrd
*Flashaholic* ,
Hawthorne, NV
Many years ago, I wired a machine using most of a 100' roll of Belden 18ga, 19-stranded. It had a problem. Took me a while to find the individual piece with the 1/8" gap in the conductor, which was invisable through the insulation. It was a brand new roll! /ubbthreads/images/graemlins/jpshakehead.gif
Larry
James S
on an island surrounded by reality
Oh I've run into that too, pulled new cable only to find out it came off the spool bad. Really aggravating! but better and easier to fix than a defective luxeon /ubbthreads/images/graemlins/smile.gif
Sway
North Carolina
Larry,
How true, I use to pull cable as a part time job and ever now and then we would end up with a bad pull I just never thought the short pieces I was using would be bad but they did come off the end roll of a long stretch the phone company was putting up.
Eh' it was lying on the bench with in easy reach live and learn /ubbthreads/images/graemlins/mecry.gif
Later
Kelly
Sway
North Carolina
Larry,
Later
Kelly
IsaacHayes
Missouri
was the cat5 you used solid wire or stranded? Solid breakes so easy. I use stranded 22gauge wire for my luxeon mods. Yes it's big, but it's durable. (except the pvc jacket, I wish it was teflon, you gotta be carefull soldering)
rwolff
Ontario, CA
[ QUOTE ]
[/ QUOTE ]
A bit off-topic, but when I bought a 1000 foot spool of Cat 5 cable (local end-of-line place had it cheap with bag of 100 connectors and a cable tester), the second thing I did (first was to try out the tester on a factory cable) was to put a connector on each end of the spool (in a cardboard box, with both ends accessible) and test my 1000 foot patch cable. In cases like this, "burning" a couple of connectors would be cheap insurance against trying to track down a bad cable after it's pulled.
The moral of the story is to test EVERYTHING before you do an assembly step that will make it harder to replace a bad component.
KevinL
At World's End
I worked for one place so bad, they wouldn't even issue us cable testers.. "no budget".
We will never know why those 3 reels were bad...
And in the end we ended up buying our own cable testers, but too late to save us that day. /ubbthreads/images/graemlins/icon23.gif /ubbthreads/images/graemlins/frown.gif
