Anybody know how to find the specs on scavenged Sanyo 18650?
seestuff
Memphis
I decided to break into the battery pack of a HP laptop that I got a few years ago that was riddled with problems from the start (the laptop that is). The battery pack is HSTNN-DB17: 10.8V --- 43Wh. What I found inside was 6 Sanyo 18650 cells. Embossed lengthwise on the side is:
SANYO L
UR18650FH K07B
And if oriented sitting on end, there's dot matrix printing that reads:
C
KAUFH55
037859
6
I googled UR18650FH and found a site called asianproducts.com that sells Sanyo Li-ion rechargeables that look similar and with the same model #. But the listing title of the batteries is not consistent with the product specifications:
SANYO Lithium-ion Rechargeable Battery UR18650FH 2000mAh
Product Name : SANYO Lithium-ion Rechargeable Battery
Model : UR18650F
Norminal Capacity : 2400mAH
Norminal Voltage : 3.7V
The title and specs are conflicting:confused:.
Does anyone here know how to verify the specs with the info I've provided?
The battery pack has been sitting in my desk drawer for over a year. I got the cells apart and cleaned the terminals from where the tabs were spot welded with my dremel sanding drum. Then I charged them in my new Pila IBC. I tried one in my Zebralight H60w and it works. But I haven't tested any runtime with it.
43Wh /10.8V = 3.98Ah
3.98Ah /2 parallel = 1.99Ah per cell.
2000mAh sounds about right.
That 10.8V pack rating is strange, based on 3.6V/cell, normally you'd see a 3S string rated as an 11.1V pack, based on 3.7V nominal per cell.
Yeah, I thought the 10.8V rating was a little weird too.
Seems like 1900 to 2000 mAh is about right for these batteries.
I wondered if there was some sort of database with the specs on raw batteries from laptop packs.
You're lucky. All I have on my sanyos is the K07E marking and the printed characters. Top one is probably some sort of model number, bottom one is a date code. No UR18650_ anything on mine, so I can only assume or guess.
BTW, I know this is an old thread, but people searching may come across it. They might also find this link useful....
http://battery.sanyo.com/en/product/lithiumion_2.html
Awesome, thank you for this !!!! lovecpf
hmmm... I wonder why sanyo did not put any information in regards to the "H" for UR18650FH . Anyone happen to know what the "H" is for ?
They put the letter "F" >F: High capacity with steady operating voltage model.
I checked the weight of the sanyo UR18650FH I have and it came up to 43.5 g
I believe it is only 2000mAh but could this be the same thing even though the weight is different?
3.7
2500/2600
18.1
64.8
47.0g​
