To me this is the definitive pot on Lod/10440. Take a good read and hope Luminescent does not put you to sleep before you are through.
https://www.candlepowerforums.com/posts/2243191&postcount=9
Sorry if the post linked above was a little long winded. :thinking:
The short version is that because the Vf of the LED emitters can change from batch to batch, YMMV (Your Milage May Vary) when using 10440's in the L0D.
When the Vf is too high, the light doesn't stay solidly in 'Direct Drive' mode and will flicker badly (this is very stressful for the boost driver, and will often fry the light in short order).
When the Vf is too low, the light will go VERY VERY HARD into 'Direct Drive' and draw so much current that the PWM Mosfet used for power mode switching may fail (even in the lower power modes).
From the statistics I see from other CPF users, it looks like only about 5% of the L0D's will fairly quickly fail (some instantly) when used with 10440's, with perhaps another 5% showing a problem or failure of some sort over time.
This means that, though you have about a 9 out of 10 chance of getting away with it, there is still a very non-trivial risk of frying your light.
It is great that about 9 out of 10 L0D's can take the severe punishment inflicted on them by 10440's (about 5 times the designed power level), because this shows that this little light is very rugged, and should be EXTREMELY reliable when used with standard Alkaline, NiMH, or Energizer L92 (Li/FeS
2) 1.5 volt lithium cells.
So, with the L0D, you can have a light that is either fair to middling reliable and EXTREAMLY bright, or fairly bright and EXTREMELY reliable (but I wouldn't count on both). It's your choice.
For me, the deciding point is that I EDC my LOD, and want to make absolutely
sure that it will work
reliably when needed; so, I stay with standard NiMH batteries.
