Re: Anyone had their SureFire battery suddenly die
Yes, I've just recently come across this probem.
It may be that the batteries are not all equally discharged. I have recently been experimenting and have a supply of SF123s batteries in various states of discharge. They work well in series in a 2, 3, or 4-cell configuration -- but only up to a point. On more than one occasion, for example, I found that my SF M3 would be working well, although perhaps getting a little yellow. I might then turn it off, and when I turned it on again, there was no light at all. Further, current was very low -- on the order of less than 100 mA.
After a lot of fooling around to find the cause of the problem, I discovered that every time this happened, one of the batteries was exhausted. I tested them under load by measuring the current drawn from each individual cell by an Arc LS head. Invariably I would get a normal 480 mA or so from each of two of the cells and about 90 mA from the third cell. Needless to say, on the third cell, the Arc was very dim.
I could then use the two good cells, and add a third cell that would work with the Arc LS. The M3 would then light again.
It appears to me that when one cell is substantially weaker than the others, the entire group of them dies quickly when the weakest falls below a certain threshold. However, there's enough juice in the good cells to be useful.
