Anyone know a good 2 AA light ?
Mags
NY
I am wondering if there is another 3watt AA powered light other than the Elektrolumens XM-3. Are there any suggestions?
A mini mag with a sandwiche in it. /ubbthreads/images/graemlins/grin.gif Yes, these things are versatile.
well well that has to be the hundredth time you have suggested
or talked about a sandwiche. Hold on, what is versatile?
I use a Lambda MiniPro Light Engine in a CNC123 bezel with 2 AA bodies & Kroll switch. It's versatile 'cos you can change the configuration to a 1x123 body & 1xAA body as well.
AA body with Kroll is on the right. Put two of those together, unscrew the tailcap from the 123 body, screw it to the bezel & screw in the 2AA body & Kroll & viola!
Another similarly versatile example would be an Arc LS with 2AA or 1x123 body.
No. Not COMMONLY available. (but then the XM3 is just vaporware right now).
The Lambda 3W High Dome drop in pill is my EDC. It has a most wonderful and useful beam using a modded minim*g reflector.
The only problem you face is an outragious wait time!!!
