Mr_Light
I have been updating a bunch of vintage flashlights and have been replacing the lenses
with Acrylic cut out of sheets using a hole saw. The basic process is:
1. Choose a hole saw about 4mm bigger than the lens, use it to cut a hole through a
piece of 1" thick wood.
2. Clamp a piece of acrylic sheet (home depot window glazing...) between the piece of
wood you just cut the hole through and a piece of scrap lumber.
3. Remove the pilot drill from the hole saw and use the predrilled piece of wood as a
jig to drill the hole through the acrylic. Be sure to not to let the hole saw get hot
enough to melt the acrylic (when cutting several holes).
4. Pop the cutout from the hole saw and trim the edges with a file or razor knife. Peel the protective paper off and you are done.
If I get a drill press I won't need the wooden drilling jig.
