Re: Anyone Successfully Mod a Fenix LD20, TK40, or TK45?
Uggg .. here's what happened tonight. First, I absolutely cannot get the head unscrewed off my other LD20r4. I heated it up for a minute with my lighter, with the flashlight body sideways in the vice with a layer of rubber between the vice grips teeth so the flashlight doesn't get scratched anymore. Well the rubber between the head and the wrench got messed up and the head got more scratched than before with more paint now off of it.
Irritated, I decided to see what I could do with the other LD20 that I got the head off already. First, I got my other neutral XPG-R5s in the mail. Tested them all and they work. So I put one in my vice and used a lighter underneath the new LED on the 16mm star. With tweasers around the LED itself it came off the star after maybe 15 seconds. Good! Now since I decided to finally unsolder the stock LED & star from the LD20, I got it off but the (+) and (-) wires retreated a little into the head. Just the very ends were still out, but I was able to grab them with my plyers. However, for some reason for both wires, the plastic sheath / outer covering came off more, so now more of the wire is exposed. It took me FOREVER to get the LED on the Fenix star. I held my lighter underneath it for a minute, still loose. Then the solder gun underneath for a minute touching the star. Still loose. I held the solder underneath for 2 minutes. Finally got it to where it wouldn't move. Took the star and soldered the stock wires back on from the Fenix. I made sure to try and push the exposed wire part from touching the star or the head.
The Fenix worked, with a much nicer tint color. I put the head back together without the plastic holder LED was still centered which was nice, but wasn't happy because the LED star wasn't secure. I took the head apart and placed the black holder of the star. Centered it and then the LED fell off. I unsoldered everything and did the same procedure to get the LED on, only this time I held the solder right under on the star for 4 minutes. Seemed secure, put it back on, and the LED falls off again. I simply just centerd the black holder and placed the LED in the center. THe light still worked but later it flickered because the LED wasn't secure. I was giving up for the night.
But then the light stopped working and the battery tube got real hot. I took the batteries out and the Eneloops were very hot. I let them sit on the basement floor for a few minutes but still hot. So I put them outside on the concrete. There was a very strange smell coming from the driver. Never smelled anything like it. I guess it was a short?
