MrAl
Hello,
Sometimes it would be nice to have an LED indicator for some common
home appliances so it's possible to know when they are running
or not. An LED indicator is easy to connect to appliances that
draw low currents by connecting a series resistor of the right
value and another resistor to limit LED current and an anti-
parallel diode to protect the LED from reverse voltages, but
what about for the higher current appliances that draw 5,10, or
even more current when operating? Sometimes it's possible to
open the appliance and add something to it to allow it to
light up an LED when it's running, but usually
it's not very desirable to modify the appliance directly.
Also, it would be nice sometimes to have a stand alone indicator
that could be used with any appliance.
The Series Resistor...
The series resistor idea doesnt work very well with high current
appliances because the size of the resistor becomes too large
and it gets too hot while the thing is running. It also could
drop an awful lot of current with some appliances, so
another idea is to use what is commonly called a
'current transformer'.
The Current Transformer...
Believe it or not, we all have several current transformers
in-the-making lying all around the house doing nothing :-)
All we have to do is take one of those dc (or ac) wall
wart adapters and convert it. This means whereever they
sell wall warts they also sell current transformers! :-)
Converting a standard wall wart into a current transformer...
To convert, follow these steps:
1. Break apart the plastic package so you can get to the
transformer itself.
2. Remove the 'primary' winding. This is the one with the
very fine wire. Sometimes a hacksaw helps, but be careful
not to damage the plastic bobbin the wire is wound onto.
3. Create a new 'primary' winding by wrapping 1 turn of
approximately #16 gauge wire around the core. This winding
should go through one side, around the back, and up though
the other side.
4. Connect a 10 ohm 10 watt resistor to the original secondary.
Connect the primary in series with an appliance that draws
approximately 10 amps. Measure the ac voltage across the
10 ohm resistor. Compute the turns ratio by dividing 100
by this voltage: Tr=100/vac
Compute the output current by io=vac/10.
Compute the excess current ie by subtracting the LED current
from io: ie=io-0.020 (20ma LED).
Compute a current diverging resistor value Rcd by taking the ie
value at the LEDs nominal voltage. Lets say the LED is 20ma at
2 volts, then Rcd=2volts/ie. Connect this resistor in PARALLEL
to the LED. The power rating for this resistor can be computed
from the LED voltage squared divided by Rcd, or P=(2^2)/Rcd.
5. Connect a 1N4002 (or similar) diode in anti-parallel to
the LED.
Remove the 10 ohm resistor, then
connect the combination of LED, resistor, and diode across the
wall warts original secondary winding.
6. Connect the primary again in series with an appliance that
draws 10 amps and check the current though the LED. It should
be around 20 milliamps.
Extra:
In step 4 above we computed the excess current by subtracting the
LED current from the output current. If the output current
happens to be LESS then the required LED current, then we need
to add more turns to the primary and then repeat step 4.
If it's say only 10ma and we need 20ma we simply double the
number of turns (add one more turn).
Part 2: Measuring appliance current using the current transformer.
If instead we wish to use our current transformer to measure the
current draw for an appliance all we have to do is skip all the
steps that mention the LED. Instead, we keep the 10 ohm resistor
connected and measure the ac voltage across it while the device
is running. If at 10 amps we measure 2 volts ac, then our scale
is 1 volt per 5 amps, or 0.2 volt per amp. If we switched to
using a 5 ohm resistor instead we would get 0.1 volt per amp.
Benefits of using the current transformer:
1. Dont have to use power resistors in series which might get hot.
2. The output is isolated from the line voltage reducing the
risk of shock. This also makes it easier to use with some
computer monitoring equipment.
3. The equivalent series impedance is very low so it doesnt
drop the voltage getting to the appliance which could
hamper the proper operation of some common appliances.
4. It's very portable...you can use the same one on several
appliances by simply inserting it into one wire of an
extension cord. Plug the cord into the wall and the device
into the socket and you can easily monitor current and/or
device running status.
5. By connecting several appliances to the same transformer you
can monitor the current to all of the appliances at once.
The total output will be the sum of that which each appliance
would produce on its own. This is especially nice when you
need to know if any of a group of devices switch 'on'...if
any one switches on the transformer produces an output.
6. The output can be half wave or full wave rectified producing
a dc output when an ac appliance is running.
Take care,
Al
transformer itself.
the other side.
the LED.
Extra:
Take care,
Al
