ARC AA help
Status
Not open for further replies.
wetdog1911
Hi all
Newbie here and a new Arc AA owner. I have a small problem in that the rubber skirt (not the O ring) seperated from the head assembly. Is this a big deal? I've had the light less than a week. Fitted it back in the main body on top of the battery and screwed the head back on. Everything worked. Should I send it back or just leave it as is? I'm very impressed with the light. Enough so that I am going to order the 5 pack special. Thanks for any input.
Wet
Hi,
Welcome to CPF! /ubbthreads/images/graemlins/smile.gif
If you look at the Arc Flashlight FAQ that's stickied at the top of this forum, you'll find this link for Arc-AAA maintenance (which is virtually identical to the AA):
http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Board=UBB31&Number=173589&page=&view=&sb=5&o=&fpart=1&vc=1
Basically, you are referring to the foam retainer on the head. It's there to keep the battery from rattling. You can contact Arc for replacements:
[ QUOTE ]
Note: Arc provides free replacement retainers and o-rings. Just send us an SASE w/a note for how many you need.
[/ QUOTE ]
Thanks for the reply. Does the skirt just glue on to the head assembly? I still have it so I'm not really sure if I need a replacement if all I have to do is glue it back on. It came off while removing the O ring to sand it down a bit to make the operation easier. (Suggested in another thread) That worked like a charm BTW with just minimal sanding with 800 grit paper. Thanks again.
Wet
The foam retainer has (had) adhesive on it. If it's no longer sticky you might have to use a small amount of glue. Personally, I would just put the retainer back in place and order some new ones and replace it when you get them. I don't like to gunk mine up. Now that you've sanded your O ring, make sure that you re-lube it.
Status
