Arc AAA still going strong after 9 hours running
Status
Not open for further replies.
pahl
South Dakota USA
I just got my first Arc yesterday. It's a black Arc AAA with green LED.
I turned it on last night around 10:00 and this morning at 7:00 it was stilling burning bright, wow!
I thought it had a 5 hour runtime or something like that. I really did not think it would still be going strong when I got up this morning.
Pretty amazing, isn't it? I can't tell you how long one lasts on a battery - mine's still on the first one! Sometimes I leave it on longer than I need it just to see if I can run it down faster. I'm a curious person, so I'm interested in seeing when it drops into moon mode for the first time. /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
Mattman said:I'm a curious person, so I'm interested in seeing when it drops into moon mode for the first time. /ubbthreads/images/graemlins/smile.gif
[/ QUOTE ]
I purposely put almost dead battery to see the "moon" light.
Started at battery voltage 0.8V and I switched off after a few hours and measured at 0.3V. Not able to switch on again.
Did not see the sudden change of brightness, but the light was quite dim towards the end, but when you see it in a dark place, you really appreciate it.
[ QUOTE ]
djpark said:
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Wow, it ran for a couple hours on 0.8 volts
I checked the batter this morning after it ran for 9 hours last night and it was 1.3 volts yet.
I put a new battery in anyway as they are so cheap. /ubbthreads/images/graemlins/smile.gif
Maybe I will have to put the old battery back in tonight and leave it on all night again just to see if it's still going in the morning again.
well. my white Arc AAA runs for about 6 hours b4 i change the battery..
on a fresh battery the beam is very white with a slightly blue plus sign in the center of the beam.. as soon as the blue takes over the entire beam i change the battery..
(i do however save the old batteries in case of emergencies, as they still put out plenty of light to navigate the dark)
[ QUOTE ]
[/ QUOTE ]
I use Arc-AAA rather often. I put a freshly charged NiMh (550maH) in the morning and leave it overnight as a night light.
Then next morning, I exchange with another battery from the charger.
DJP
Status
