CNC Dan
<font size="2" face="Verdana, Arial">I can make it like the other pic with the taper from the body to the head section. And I could also make a rounded sweep (convex then concave). The latest pic is square with a slight radius on the out side corner. I made it this way to see how light I could make it. It is not hard to change it though so I may make several styles. The wall is too thin to knurl after the inside is drilled or I would do that. I may add a bunch of fine groves along the smaller diameter. I am hopeing to get some 1/2 inch aluminium in so I can make some out of that. I used to have about 20, 12 foot bars of 1/2 aluminum leftover from a job, but that was before I found CPF. Lots of brass though.
Prehaps I will get a chance to sneek some in on a weekend. They only take 2 min. each once the machine is setup. If I am running a simmilar job it shouldn't take long to setup. Timing is the key. If I do make some, I probably run off two bars worth.
I could try some 303 stainless.
That shouldn't be too hard. But 17-4 PH would look better and be lighter, but it is hard to machine. We'll just have to see.
