ARC LS hybrid MSU-proof?
Status
Not open for further replies.
jack_flash
While testing and measuring the ARC LS hybrid 400 mA I noticed, that current didn't increase much with voltages over 3.5 volt. From 3.5 to 5 volt current consumption was about 350 to 380 mA.
Common step up circuits are leading power through inductor and diode direct to the output, which means here the LS-LED. This should cause a maybe deadly current through the LED with input voltages above 3.3 volt.
But not here. The only thing I had everytime, esp. with voltages arround 2.5 volt, were current spikes above 1 amp.
So what's the circuit? (seems to work with a LT16xx chip because of behavior)
IMHO there is a Multifuse-Polyswitch added, which acts as a reversible fuse or current limiter.
Is this flashlight Most Stupid User (MSU) proof or not?
Status
