Ok, This is what I have so far. Still decoding the suppliers codes and will update.
O-rings and Retainers for all flashlights
AAA
Head: 9x1.5mm(5/16x7/16x1/16) buna
LED seal: -006 buna
Retainer: .187 x .453 x .093 poron
AA
Head:
LED seal: 006 buna
Retainer:
LS Rev2 Series
Lens Cavity: 17.5mm x 1mm buna
Battery pack: 1x18mm (3/4x7/8x1/16) buna
Switch: Mfg by Judco for Streamlight JR switch, used with permission (sold by Kroll International)
LS Rev1 series
Retainer: .375 X .640 X ? Poron
Battery Pack: 1x17mm?
Arc4
Lens cavity: 20x1mm Buna
Battery pack: 22x1mm Buna
LED seal: 5/16 OD X 7/32 ID X 1/32 thick Poron
Button cap: 19mm x 1mm Buna
Lens Size: 0.895 x 0.093, Polycarbonate (Lexan)
Clips Screws: Stainless Steel, 4-40 3/16” pan head
Grease: Carbon conductive around edge of gold plated negative battery contact spring, all other sliding surfaces use silicon grease or similar.
Unless otherwise specified, all o-rings are 70 durometer Buna.
“Poron” is a closed cell, silicon sponge rubber with zero memory. PSA is applied to the back side to facilitate application.
The AAA retainer was used under the rubber button in some Arc4s to improve switch feel.
Peter
