Re: ARC-LS circuit boost
Yes I can. I just heat it carefully using heat gun, and strip the epoxy. Tested after all epoxy has been stripped, and it still work perfectly.
You have to strip the epoxy little by litle very carefully, since you can only guess the location of all component. If you happen to know where all of the component are located, your work should be easier.
Just e-mail me if you want some picture of it (to know approximate component location), since I don't know whether it is legal to post pic of the circuit board in open forum like this.
