Arc LS value?
Status
Not open for further replies.
MikeLip
Painesville, Ohio, USA
OK, stupid question. I have an Arc LS First Run, #008. I also have the AA battery tube and the 1 CR123 tube. Everything has been used about once. Since I don't use it and don't collect, I'd like to get it to a better home. But I have no idea what it's worth. A scan of the FS board isn't much help. Any ideas?
Mike
Well, there's always ebay, but I'd say certainly in the $200 range and maybe quite a bit higher.
Mike, you can look this up with the search function.
Forum: B/S/T~Lights
Keyword: "+first +run" (don't forget the space, but don't use the quotation marks)
Username Search: leave this blank
Date Range: Newer than one year
Check "Display all Main Posts"
I tried to just link to the results of this search, but for some reason the results get screwed up when you do this.
Peter
Status
