I just got my Arc4 second, popped in the Kodak Max 123 batteries, made sure it was on highest setting (forced boost no change) and left it on.
1.5 hours continuous!
Now for the problem. This is not possible for an overdriven 1W LED. Questions:
The temperature alone should force it to step down after 20 minutes right?
Maybe I had a super battery?
Or since it is a "second" it may not be reaching max brightness (30 lumens) as advertised and instead is reaching level 2 brightness which would be more inline with the 1.5 hours continuous... but would the brightness effect power usage with the regulated current?
Seems like at lvl 1 brightness it should use the same amount of energy for all Arc4 even though the actual lumen output might be less from a bad LED... or am I wrong?
Anyways maybe someone could explain to me how I can get 1.5 hours from lvl 1 max brightness. I dont have any way of measure the light levels (newb:))
BTW no real cosmetic flaws (im not too picky) except some white filament strings near the LED which dont affect performance at all)
