To make the 2x123 pack work with the copia 150 cell, there would have to be quite a tolerance for cell length. The current switch design is not as friendly to this as a new switch design will be. However, there are other options at this time that I find more attractive.
The 2x123 pack was really intended to be used with the Arc5. As was stated earlier, the Arc5 is being delayed until next year because we already have a lot to do this year.
The other reason to make the 2x123 pack was for the copia 150 cell. However, that was before I had a chance to test the rechargeable LiIon 123s that JSB found. I have tested these cells and have observed usefull performance. Now that the the cell voltage is increased, I get several weeks of average use from each cell. My goal is foremost for EDC use. The 123 LiIon provides good run times in a compact, easy to carry package. Therefore, I strongly recommend the 123 cells for rechargeable use.
Jon and I are putting together a deal where Arc will offer cells and chargers on our website to be used with the Arc4.
Now I understand that a lot of you have invested in the copia system and it would be nice if it could also be used. With the smaller 123 solution providing good run times, the larger copia solution is too bulky in my opinion. However, the Arc5 will be able to put more powerful packs to good use so I can see the copias being more important for the Arc5.
Peter
